TwinTurbo.NET: Nissan 300ZX forum - Re: Yup, changed those out. Every component on the rear
Subject Re: Yup, changed those out. Every component on the rear
Posted by sandmanz32 on April 10, 2008 at 3:27 PM
  This message has been viewed 151 times.
In Reply To Yup, changed those out. Every component on the rear posted by Audioquest on April 10, 2008 at 08:07 AM
Message hmmm thats odd. those are really the only things that can leak on the rear. is the housing itself cracked? even slightly? sorry i missed in your first post that you said you replaced the end seal on the oil pan. if the crank isn't wore or damgaed that should be the problem. is the spring staying in the seal when you install it?
Hondas are like Tampons; every pussy has one!
So, which Formula 1 Car are you most like?
